SpotlightReplacing lighting devices
Command
Workspace: Path
Shortcut
Replace Lighting Devices
Design Suite: Entertainment > Lighting
Spotlight: Spotlight > Lighting
Ctrl+Shift+Alt+R (Windows)
Cmd+Shift+Option+R (Mac)
Replacing a single lighting device
To replace an individual lighting device with another type of device:
Select the existing device.
From the Object Info palette, click Replace Lighting Device.
From the Resource Selector, double-click the replacement device.
Replacing selected lighting devices
To replace selected lighting devices with another type of lighting device:
Select the lighting devices to be replaced.
Select the command.
The Replace Lighting Devices dialog box opens.
Click Replace selected lighting devices.
Click the Resource Selector, and double-click a resource to select it.
Replacing all lighting devices of one type
This command applies to lighting devices that are visible and editable. It does not replace all lighting devices symbols of one type in the file. To do that, see Deleting a symbol definition.
To replace all lighting devices of one type:
Select the command.
Click Replace All.
Editing lighting devices
Inserting lighting devices
